compensating for relatively humidity
Hi folks,
as many of you will know I now live in a much warmer and more humid environment (than melbourne) - and i was just wondering what other folks in similar climates did to compensate for increased humidity, when grinding and making their coffee?
I tend to find that the beans are moisture rich already, and Im not convinced that a relatively fine grind and 'down-dosing' which seems to be the norm in 'hipster' cafes is necessarily the best way to go
thoughts people?
P
  • I'm now updosing (22g basket) and thus grinding a little coarser.  I've also swapped the VST for a Pesado Basket from Dolo which seems to be as good as the VST.  I leave my beans on the bench in the tins I covered a while back from Campos.  They're not cheap but they are holding up well and I think they make a difference to my consistency.  In th end I think it is what is it is!  One man's symptomatic discrepancies is another man's Mother's Milk.
  • Agree I seem to get the most out of my coffee on 22g slightly coaser grind - but that also suits the beans and the roast profile I'm guessing I would do things differently for a central American based blend on a lighter roast profile (for instance) P
  • To avoid to many variables I stick with my 22 grams and make my adjustments for maintaining taste by way of grind, yield and extraction time.  The Slayer design also allows a bit more flavour control depending on how you use that paddle.
  • on 1486216548:
    Oh must be great to have all those added variables to play with!  Does manual control of the flow rate mean that you can dial the grind in a lot finer (than other espresso machines) ?
