A riveting topic to me hehe, let's talk ristrettos! Riveting ristrettos run really reluctantly reduced and restricted!
Just wondering a few things...
1) What really is the difference between a ristretto and an overextracted shot, what makes it different, and how do you not produce an overextracted shot when brewing up a ristretto? Obviously tastewise very different, but how can you avoid overextraction when pulling a ristretto? I'm sure it would come down to the bean.. I've pulled ristrettos with some that have been heavenly, and others that were just not great and didn't seem suited...
2) How have you found the most effective method to prepare it? As far as I know there are three main ways: Grinding finer, updosing, or pulling the shot early (Or a combo of those).
(The most common definition I see is pulling a 1:1 ratio shot in roughly 35 seconds, which obviously entails a slower shot, otherwise can be achieved by pulling a shot shorter)
I find that grinding finer works well, but it would probably be easier to either cut a shot short or really updosing as it can be tricky to just switch it up for the next shot and assuring you'll get the right grind fineness and also that the new grind has worked its way through (although updosing can be limited in application at times depending on current basket dose you're using..)
Curious as to your thoughts
