Using stale grounds.
I actually collected the debris over a week or so in the waste tray of my Mazzer Mini, no special treatment, just left em lay where they were till I had enough, when I had sufficient I pulled a shot, you know it wasn't all that bad, I've certainly had much worse that has cost me $3.50 a cup.
Certainly make ya wonder about the processes employed by some commercial establishments. ;)
  • I use the Old grinds left in the grinder and sweepings off the bench to run a dummy shot through the machine once I've back flushed - even so these grinds are prob less than five mins old and I've been known to make myself a coffee from time to time from sweepings and as you say I've had much worse coffee elsewhere...
  • on 1282292514:
    We need to encourage a few more intrepid posters from the other side Mate, if we could just get a dozen or so regulars the site would gain a bit of momentum. ;)
  • Too right mate! I think that just the process of regular posting will build momentum
  • on 1282303860:
    on 1282292514:
    Sprinkle on the garden and around teh veggies... Helps to keep the snails off   :o
    Not sure about that AM, have been dumping used grounds onto front garden for about 6 years, still plenty of snails but the coffee has certainly helped improve the soil. ;)
  • on 1282303860:
    Agreed I find coffee grind around the veges keeps both snails and feral pooping cats away!
  • I thought i saw something on some sort of scheme for cafes on this [out of Melbourne?] - does anyone know if this got off the ground? A
  • on 1282716869:
    Yeah we're part of the initiative - it was stared by steve Agi - it was called ground zero, but now it has a new name which escapes me Grinds can be collected once a week  or fortnightly and are recycled into compost - folks can personal message me if they're interested in more details...
  • are coffee grounds definitely ok for the garden. Does anyone know for sure?
  • on 1284072886:
    You bet they are, been using them around my roses for the past 10 years, they're thriving. ;) http://www.lavazza.com.au/pr_recycle.htm
