cleaning atomic machine
:( I have an old Atomic coffee machine which has not been used for sometime.
What can I use to clean the inside
  • you can clean it with a dilute bleach solution and a soft bristled brush but whatever you do try and avoid scratching any surfaces as this will just lead to a build up of rancid oils and / or nasty bacteria there are also professional cleaning products such as cafetto (which is australian owned which are designed specifically for the job, and maany commercial and 'boutique' roasters sell these cleaning products online you might even find them on the bay of evil cheers, pat
  • Thanks a lot Pat. I'll give it a go.
