After reading about shape_shifters modifications to her popper and reading about the many adjustments she can make to extend a roast, a friend and myself decided to give some poppers our variation of a popper modification.
As my mate already had a Kambrook popper, I purchased another so we could modify the two of them together, and, seeing as he is a bit of a tech head, we stripped the 1st popper down to see what was going on inside this little machine.
Pretty simple to tear these things apart as long as you have a torx screw driver for just one of the screws underneath the popper. The little plug that holds the power chord that enters the machine was removed with a pair of long nosed pliers and a little prying with a very small screw driver.
WARNING....IF YOU DON'T KNOW WHAT YOU ARE DOING WITH ELECTRICITY, DON'T ATTEMPT THIS AS IT MAY KILL YOU.
It did not take too long to discover that the fan is being supplied by 20 volts and the element is being fed by 240 volts. We then decided to go to Jaycar and buy some goodies. A couple of black plastic boxes, a few sockets and also a few switches.
We separated the two systems so we could test the fan first without the element being turned on.
Our first thoughts were to buy a 24 volt/1.25amp DC power pack and try that for the fan, however, this idea quickly got knocked on the head as we discovered that the fan requires a tad more, in fact a lot more than 1.25 amps, as the fan was pulsating due to power loss. We then had to go to a little more expensive unit and buy a 115 watt, 24 volt (variable) 6amp general laptop power supply from Jaycar. Once we tried one of these, we knew we were on a winner. Wow, once you give that little fan 24 volts, the increase of the fan speed was incredible. It worked out really well as we quickly discovered you can change the fan speed whilst the fan is still running.
We then bought a stove-top control to change the heating element. That was a complete failure as it required a thermostat and that was just not going to work. So we scratched our heads and came up with the idea of using a 1200watt/220-240volt light dimmer. We bought two of these off eBay. They were cheap as chips and as soon as we tried one we knew it is was an instant success. These dimmers were slightly modified by trimming a small amount of aluminium off their mounting brackets so they would fit into the plastic box and then they were super glued into place. The external section of the box was then marked into 9 equal positions with a hand held drill bit and the small indentations were then filled in with white touch up car paint.
Having purchased the black plastic boxes prior to determining that the initial power supply was not up to scratch, we were forced to mount the newer and much larger fan power supply to the outside of the box and run some external wiring back into the box. Once again, this was done with super glue. Probably not as neat as we would have liked but still quite acceptable. Bugger!!
We have discovered that the heated air from the element is changed by the fan speed. The extra air rushing past the element is cooling the element down so it is a balance between ambient temperature/fan speed and element control to achieve exactly what profile of roast is required.
With 110 grams of beans in the popper and
only the fan switched on at 24 volts the fan has a tendency to throw the odd bean out of the chimney. This gives you some idea of the power of the fan at 24 volts. This power will never be needed. However, it is an indication that the quantity of beans may well be increased in future tests.
At the moment, 18 volts on the fan and the heating element set at 7 gives a nice extended roast time in excess of 13 minutes with an ambient temperature of 20 degrees.
At the present time, I am roasting with the aid of an Infrared Temperature gun which is NOT considered to be as reliable and consistent as using a probe direct into the bean mass. This will be the next addition to the power pack/light dimmer popper.
I have to keep telling myself now, don't fiddle with the controls!!
This is the complete package. The green switch supplies power to the fan and the element. The element cannot be operated without the fan switched on. The red switch is the element and the knob is the element control varying from 1 to 9.
This is the top view of the unit showing the power light and the fan voltage control.
This is a closer view of the fan voltage control. You can see clearly that it is set at 18 volts. Each change is defined by a nice solid 'click'.
This is the rear view of the unit showing a USB port and power socket.
