Troubleshooting RoastMonitor s/w problems.
One software package popular with home roasters is RoastMonitor. It has been available for quite some time and is currently available for download at no charge.
Hopefully this thread will offer some assistance to those having trouble getting it up and running as, for various reasons, getting community troubleshooting assistance for RoastMonitor can be awkward. I noticed a post from someone on another forum (coffeesnobs) who was unable to get the software to recognise their data logging meter.
The goal of troubleshooting is to identify where the root cause lies - having access to different software packages can be a great assistance in this and roastlogger provides similar functionality to RoastMonitor, but implemented in a different way.
The response I gave them follows:
[begin quote]
Try roastlogger s/w. If that works, then you know it is a problem with how you configured the RoastMonitor s/w.
If roastlogger also has problems seeing the meter, then you know it is not the roastmonitor set-up. Also, errors from two different s/w packages will give you more information to work with.
I'm not saying you necessarily want to use alternate software long term - many snobs like the roastmonitor s/w and are very happy with it.
[end quote]
  • I am amongst those to have had issues getting the software offered with my meters to work. http://coffeesnobs.com.au/YaBB.pl?num=1236075603 the general instructions offered here will sort most people out but most of my problems were coming from Microsoft .net flakiness I suspect. I do see some suggestions about winding back to earlier versions of .net but that is a pain for other things then.  :doh: For me that resulted in doing some searching around for a simple solution which saw me here http://homepage.ntlworld.com/green_bean/coffee/roastlogger/roastlogger.htm which doesn't need .net at all and I have had it running successfully on XP and Win7 (64bit). It logs 2 simultaneous meters at once plus a host of other features including being compatible with some of the TC4 based Arduino boards. Bonus for the Apple and Linux users it will work for you too. :thumb:
