I thought we might start a thread for discussing PID related matters. I understand the variables at play (different coffee bean roasts, different coffee machines, PID reporting temps that are perhaps not absolute) make it very difficult to get a true baseline on matching espresso flavours between members, but I'd still be interested in other's reports.
Brett in particular has found some interesting correlations between temperature and his Java Kalistat roast (which I miss terribly) and I'd be interested to see what others say.
I'd also like to find out a little bit more about the functioning of my PID. When I turned it on this morning I had a bit of an odd experience - all zeros showing on the display for a while. I hit the 'up' button and then it started counting up - but given the 'boiling' sounds from within, the numbers on the display didn't match the temp. I hit the 'up' button again, which set the display to 'off' and boiling stopped.
I wound up pulling the old IT trick - turned her off and on again - and all was well with the world. I'd like to find out more about how my Bezzera BZ07 PID is supposed to work.
