Roast Profile Adjustments for Bean Density/Moisture
I'm using professional roasting equipment for small batch roasting. My roaster's max capacity is 10 kilo. I have PID controls too.
My question is: How will a roast profile need to be adjusted to compensate for more dense beans (ie, high grown PNG, as opposed to, say, an Indian Monsooned Malabar). Also, how does moisture content factor in to roasting?
Correct me if I'm wrong (or expand my understanding), but from what I understand, a more dense and/or moist green bean will require greater energy to roast. I'm also guessing this would cause the rate of rise to be less during roasting, as well as the bean/atmospheric equilibrium temperature to be lower at the start of the roast just after dropping the beans.
How should a roast profile be adjusted to compensate for higher density and/or moisture?...like, a longer roast time, higher end temp, flatter curve, etc. Once the bean drys out (I'm assuming around first crack) will the roast personality change?....like, a faster rate of rise, more difficulty in keeping temps aligned with the profile, a spike in temp at the end of the roast, etc.
Also, are denser beans better suited for higher temp roasts, such as espresso, whereas less dense better suited for cinnamon/city type roasts?
Any comments, links, resources, graphs, books, ANYTHING would be super helpful. I'm not finding much on this topic.
Thanks
