What Is Your KKTO Technique?
                    Would like to share my current technique on the KKTO.
Previously used to burp the oven and turn down the heat setting (to 225 deg celcius on my oven) upon first crack stage. Then turn down further to 220 degrees halfway to second crack.
These days I found a better result if the heat dial was turned down a tad at the start of first crack( just under the max 250 deg mark) and just burp occasionally for air flow through from rolling first crack to start of second crack.
The cupping results seem to be better than the previous version.
Strictly hard beans are roasted on full heat from start. Others I start at 225 degrees then full heat when I see color change starting.
What are your thoughts and do you have your own way of roasting on the KKTO?
