removal of collar
edited July 2013 in Grinders
can anyone give me some tips on how to remove the collar from our Eureka bag grinder, please?
  • on 1373504904:
    By the look of the photos the collar is part of the housing So I would unscrew those 4 cap screws to remove You may also need to remove the grind size dial as well ( probably secured with a grub screw needing an Allan key ) KK
  • Did all of that, KK, but could not get it off. Been searching for options, but there is not a lot of info around on them. I will try again and post some pics of how far I get with it. thanks :) L
  • on 1373511810:
    It may need to be prized open as it may have a gasket or coffee oils are working like glue
  • Thanks, KK... will give it another go when i am back on my feet ;)
  • Got it off! :) Ran a few kg of rice through it and it must have warmed/ loosened up the oils sufficiently to allow the collar to come off. So, now the top is off, and I have the bottom burr off ( almost needed a cold chisel...) Tips on removing the burr carrier? clock-wise/counter clockwise or just lift off after a drip- soak of Cafetto?? ;) L
  • I've no experience with these Lizzi but Derilex had a thread on his Eureka 64mm that would be worth a quick read: http://www.bestcafes.com.au/forum/grinders/the-grinder-cometh/msg26380/#msg26380 Post 26 shows pics of the burr plates
  • Thanks Brett, will have a peek ;)
  • new burrs are on order, but still would love to get the burr carrier off... Looking at the spindle it could just be tapered.... but not a great deal of space to try and lever it off. WD40 ( and patience) to the rescue, unless anyone has anything else to suggest.
  • on 1373786174:
    :tearhair:
    Is it a left hand thread? Possible that you are trying to tighten it? Cafin8td
  • not tried anything yet, hence my question before:
    on 1373770501:
    Tips on removing the bottom burr carrier? clock-wise/counter clockwise or just lift off after a drip- soak of Cafetto?
  • Looking at the pic Lizzi I would say you need special tool # 12345 :D. Or the same stlye of tool used to change the cutting discs on angle grinders. A second tool to hold the 2 lugs sticking up ( could get away with a flat bar but something purpose built would be better - like a piece of timber with a saw cut in the bottom maybe)
  • ... then,  i will wait for BF to dismantle his...  >:D IF we need a special tool, once he gets his done, i might bribe him to let me borrow it  :thumb: ;) L
  • Nah. Invent , create, succeed -    or break  :rofl:
  • all for doing a girl-mod, D, but if BF can get the darn thing off his way, happy to follow ;)
  • Ok...,I gave up. Could not get the bottom burr carrier off, so cleaned underneath with the help of cut-off zip ties and Cafetto-wipes. Everything  looks spic and span now, new burrs fitted ( thank you, Coffeeparts ;) and put together again. Ran the first bag through... booodifool! No heat, just lovely ground coffee smell.  ^-^ Good for another many KG's. Happy Lizzi! ;) L
  • on 1374031123:
    Brilliant Lizzi!  Where did you get this grinder if you don't mind me asking?
  • The Bay of Good Intentions ( and Evil Decisions ;)  ), Brett. We got her about a year ago for the commercial side of my coffee-fascination and ran her on a grind setting most suitable for the average Hardly Normal machine. She ran a tad hot, though, and i decided to tidy and tart her a bit. Shame about the bottom burr carrier, but i am comfortable that she is clean enough to produce good grinds again. ;) L
  • Ahhhh, but you still don't know how to get it off. That would drive me crazy. I would loose sleep over that.  :rofl:
  • Very true, D... and I am losing a tiny bit of  sleep over it.  :tearhair: However, I also know that BF will find a way to get it off, and then I will be able to do it as well  :rofl: Hasten slowly... In all seriousness: I needed the grinder for tomorrow's shipment,  so function before beauty! ;) L
