kmart/bunnings KKTO Roaster
Project started on the weekend: to build a KKTO Roaster with as much of the gear sourced at kmart & bunnings as possible.
purchases so far:
kmart multi-cooker: $27
kmart stockpot: $16
kmart TO : $39
the TO fits almost perfectly onto the stockpot, which fits the pastapot with handles taken off. the pasta pot set also includes a steamer tray which is perfect for a bean cooler.
drive shaft part 1 will be an 8mm bolt onto a 13mm socket, holding an agitator made of copper pipe partly crushed to form a triangle.
part 2 will be another 8mm bolt going down and attaching via some skateboard bearings to the outer pot.
the whole thing will sit on a stand made out of makerbeam (15mm aluminium extrusion setup).
