Identifying Compak? grinder
Hi all
I had a look at a second hand grinder today. The data plate has been cleaned off over the years but by the looks of it I think it's a Compak K6? I've attached a couple of photos of it, the height to the top of the hopper was 590 mm and the base 395 mm.
I couldn't work out how to adjust the grind there seems to be grind adjustment latch on the left side of the body as you are looking at the grinder. But even when I pressed this down I couldn't get the adjusting collar to undo.
I'm presently using a rancilio md40 that I've de dosered and de hoppered but always looking to upgrade, however I'm not sure if I'm going to get WAF on this as it seems pretty big.
