Gaggia Classic and Grinder
I have a Gaggia Classic and a Gaggia Grinder and was wondering if anyone else out there has one so I can ask some stuff....
1) When I switch from espresso to steam once the pressure has built up (when the red light comes on) my steam wand seems to always let out a little steam even though it's still quite securely off. Also, even when in standby mode it seems to seep a little water and steam. I always release any remaining pressure when switching back to standby. Is this normal? Does it need a service? How do you do a clean on these things... like a descale?
2) I also have the 'Cafe' style grinder where you can grind the coffee and dispense a measured dose into the group mandle. There's about 40 grind settings on this thing. I usually find that I use settings between 6 and 8 depending on the coffee - anything greater than this just makes it too fine - why do they make such a large number of grind settings? Also - anyone have any tips, tricks or suggestions on using the grinder?
Nick
