Water pressure for home machine ??????
A question for some plumbing type person. I looked at a few other headings but this is slightly off the plumbing track.
I looked at this site once a week, it usually helps with any problems and is informative.
I have resurected my brothers old expresso machine which he wasnt using as he is overseas.
It has a rotary pump.
I took all the fittings, including undersink filters and a pressure reducer he told me to take. I have hooked it all up and it seems to be running well.
My question after all that is ??
When I take the water line off the machine and let it run, there doesnt seem to be a lot of pressure. Its coming out okay but not like a hose I guess. Its only small tubing, say 6-7 mm but I thought it would be squirting out harder.
I rang my bro oseas and he said the filter and pressure reducer do this. Its 350 kpa he told me. I also changed filters to make sure that was okay.
Can low pressure harm my machine. Or will it just fill slower, or is this all okay and Im paranoid. Its better than high pressure I guess so I dont get a leak.
As I say it all works well and the machine is 5-7 years old I just wanted a professional opinion.
thankyou
RUDI
