I have built my KKTO with help of DIY pros who has built their kkto as well.
my kkto is slightly different from the one that can buy, which this makes a variable when comparing results of the roast and the roasting time.
In my set up, i do not have a DMM which makes roast profiling difficult, so i have to listen carefully...
Other method that has been posted ( 5min thaw/140degrees?full power) does not make it to over 18min.
what i have experimented was to start 5min thaw, and increase temp to 175, and 5min later, 200 degree, reach first crack, then ramp up to 225 degree.I normally stop at very beginning of second crack. this will take around 19min total including thaw.
first crack is around 15 min..
I havent changed the amount of roast from the first roast, sticking with 600g.
7or 8 roasts so far....
so my question is in my situation, should i get a DMM for a better visualizer to roast?
Does any of members use DMM with mac without issues?
i will appreciate any advice
cheers,
shige
