Hi all.
Someone told me the best way to test a coffees flavour, after roasting, is this.
Make the grind a little coarser than you would normally have for an espresso,
approximately the same you would have if using a perc. Put 10 grams of ground
coffee in a cup, with 180 to 200 mls of hot water, slightly below boiling point.
This was a barista telling me this. He said this is the best way to taste the
characteristics of a coffee. Apparently they use this method at the Robert Timms
factory in Concord.
On a separate occasion, i was told arabica coffee is better quality than robusta, but
robusta gives better crema. So i roasted some Ethiopian Yirgacheffe, very nice sweet
coffee. But when i added some Indian AB cherry robusta, i lost some of the sweetness
and aroma in the coffee.
Surprise, surprise!!! So what do i do about that? What is the answer to that?
Do i add robusta to arabica to increase crema, but keep it to an absolute minimum, so
as to lose minimum flavour.
Or is it that maybe Yirgacheffe doesn't blend well with robusta, and i should try
something else instead, like blending robusta with an indonesian or mexican arabica coffee.
Any help, suggestions?
Thanks in advance.
