Grind v Tamp v Cake - Relationship
Obviously, there is a direct relationship between the fineness of grind and the pressure of the tamp.
In mathematical terms, I'm guessing that :
Grind + Tamp = Crema (meaning, the coarser the grind, the more pressure is required in the tamp....and the finer the grind, then less pressure is required in the tamp) feel free to correct me if I am wrong.
A bi-product of the Grind and Tamp process (apart from the Crema that is produced), would be the "cake" that is left behind. Again, I'm guessing that it shouldn't be too sludgy.
This morning I've been experimenting with Grind and Tamp and having various degrees of success with the Crema & Cake that has resulted. Perhaps, too much spare time on my hands ;D
If the guage on the front of the machine is any indicator (I think it is probably indicating pressure required to force water through the grind), I am frequently tamping too hard as it is indicating an "over extraction".
I have set the Solis Maestro Pro to the "Espresso" setting (between "Drip" and "Turkish")....and would assume that some tamping is required.
As mentioned, the guage is frequently indicating an over extraction. If I cut back on the fineness of the grind, the resulting espresso seems too "runny" to me as it drops from the PF....and a sludgy cake is produced
Am I paying too much attention to the guage ?
Should the aim be to produce a grind that is so "correct", that tamping is not required ?
Should I find another hobby ?
Please ease my confusion. ???
