Isomac Vs Giotto (Rocket)
OK recently purchased an Isomac Millennium, a friend has an EMC Giotto, the machines are about the same size and capacity, the Millennium is slightly cheaper than the Giotto about $100. So far so good with the Millennium, the Giotto has run well for my friend also.........so what do others think obviously I am biased toward the Millennium. Over to you!!
  • Further to this, has anyone had to adjust the preasure stat on a Isomac??
  • Hi there - both great machines; slightly different interiors [as well as exteriors] but from my understanding you can make both coffee with both. Really difficult to to rate one above the other as they both pretty much perform the same from a functional basis - the rest is personal preference! -A
