fitting out a coffee van!
edited September 2017 in Have your say
anyone got experience fitting out a coffee van ?
a client of mine has got approval to do coffee at Woodford folk festival and is getting a van fitted out to cope with demand !
they're a little new to the coffee game and I'm helping them out - I have my own ideas but what do others think ?
pat
  • If you look back over the years Attilio's son fitted out and ran a van. I'd be giving him a call at Cosmorex/CRA. Having looked a a few and even considered one in my youth the big issue is the power and cold storage.  Pictures, pictures, pictures!
  • on 1505776533:
    yep those are pretty much my two main concerns in a nutshell - before i moved up from melbourne I was among other things running coffee stalls at promotions and events etc and we had some type of device that plugged into the power supply that ensured a continuous source of power to the machine - ill have to get hold of the guys and find out what that device was unless anyone else knows? p
  • And... the good oil on generators is that you buy the very best you can afford and one with a name you recognise like Honda.  Every dollar you save on a generator now will bite you in the arse when you can least afford it!
  • Just seen this new thread Yes I agree with what Brett has posted Contact Atilio Get the very best and most reliable critical equipment available KK
  • on 1505803376:
    true that and in response to the previous post are we talking about using a generator to power the coffee machine or as a backup power supply ?
  • Where you can, use their power. Most 'market' machines have a leg wired out of the boiler element so they're 10amp.  Also, get a 3-phase to single-phase converter to keep in the van just in case. They're cheap and so very useful when you turn up to a council location. I did lots of research and recon on this years ago.
  • on 1505867252:
    sounds like good advice the last thing you want is to run out of grunt when the demand is on! P
