Since posting the "reverse plunge" technique for the Bodum, I've refined the timing and coarseness of the grind accordingly. It all started with the article form "coffeenavigated.net/grinder/fines".
Using the knowledge from this, the reverse plunge offers a great tasting coffee. I'm hooked.
Pour the water onto the grinds
Gently stir to soak & start timer
Plunge the grinds to the bottom and then slightly lift.
After 4 minutes 20 - 25 seconds, lift the plunger fully and then plunge down.
