experimenting with extraction
edited February 2013 in Have your say
  • Interesting stuff A! I might have to give that a shot!
  • G'Day Ashley, long time no talk! Interesting method, will give it a go and report back. :)
  • Would it not make sense to reverse the fine and the course? Fine on top, course on the bottom.
  • Hi Ewan - my theory on that was that you would therefore get the most out of the fine half of the extraction [first] and then it would rush down through the courser grind second [since it was at the bottom] adding an element of under-extraction... my thinking was that it's better to have the fine at the bottom to keep it extracting that little bit longer in the [courser] top half... Of course at the end of the day, it's whatever works for you, but that was my theory! A
