Voltage issue
Do I need to change the volatage of my (american) krups coffee machine to use it in Europe?
Thanks!
  • Hey R - voltage in US is different from Europe [& from almost the whole of the rest of the world] - so assuming your Krups is like most other appliances, you would definitely need to change to 230/240 V. -L
  • no disrespect intended but Krups is hardly top of the range or particularly expensive - wouldn't you be better off getting a new machine once you got there? pat
  • Hi Rodrigotascon - occasionally we have a problem with our member registration, and someone's membership gets dropped off. Apologies, but looks like this has happened with yours - sincerely apologise - would you mind re-registering? Apologies again. -A
